akilesh
(Akilesh Ayyar)
April 16, 2022, 6:42pm
1
So I’m trying to monitor the comments section of this page:
Recently, I have seen a lot of competitors, even smart and experienced competitors, make their lives unnecessarily harder and throw kilos away on the platform by cutting weight for a meet poorly. There are lots of smart ways to cut weight, and I'm...
I believe I selected it in the visual selector successfully, and choose to run the checks on Chrome at 5 second intervals.
If I manually trigger it, it just says “Loading” indefinitely.
And otherwise no checks seem to be happening.
I will say that the website has a popup “subscribe to my email newsletter” when it is first fetched; I’m not sure if that’s interfering in any way.
Any ideas? Thanks.
ajitk
(Ajit K)
April 17, 2022, 7:45am
2
Hi @akilesh , thanks for using Distill and posting here on the community forum.
Can you check what device is set to run this monitor[1]?
It most likely is is a local monitor. In that case, please try using the the extension’s Watchlist to run the checks:
Click Distill icon in the browser toolbar to go to the Watchlist
Select the monitor and check it for changes.
Feel free to reply if you face any issue.
Cheers!
[1] Local Monitor vs. Cloud Monitor | Distill.io
akilesh
(Akilesh Ayyar)
April 17, 2022, 4:07pm
3
Well, I was running it under the “Chrome” option, but I didn’t even realize that I had to install an extension. When I installed the Chrome extension, it all worked. Thank you!
ajitk
(Ajit K)
April 20, 2022, 9:18am
4
One needs to go to the extension’s Watchlist to access the extension’s settings. The steps to go to the is shown here: https://forums.distill.io/t/need-to-open-in-new-window-instead-of-tab/366/4 .
Hope this helps!
