I’m trying to monitor a website which requires login. Works fine when I use it at home when my PC is on as it’s already logged in. However i’d like to use to ping through the cloud monitor. When trying to create it wants the log in.
Is it possible to use my own proxy and login to my website, then monitor what I need to from the cloud?
the website is keepa.com
A macro can be used to login automatically before checking it for changes. Check out Macro: Record and Replay Automated Actions – Distill. The video tutorial in the doc should be a good intro to using macro to automate steps in Distill.
Thanks for your response. I’ve had a look at this and created a macro to log into the site. Once logged it, it redirects itself to the homescreen. Is it possible to edit the macro to execute the url which was initially specified again after the login has taken place?
