When I push icon, it only shows a small blank box
My brave browser extention does not work from few hours ago, too.
When I push distill icon, it only shows a small blank box.
@aaidee Can you try removing the Distill extension from the Brave browser completely, then reinstall the extension again and check if it starts working properly?
If the issue still continues after reinstalling, I would recommend using Chrome or Edge browser instead, as they tend to work more reliably with the extension.
I found that it is because of Brave web browser. It works well after first installing distill extention. But if fails and show only blank box after restarting Brave web browser.
If I remove distill extension app and reinstall it, it works well.
But after restarting Brave web browser, it fails agein.
Brave web browser is making this problem.
Thank you.
@aaidee Thanks for the update, and glad you were able to identify the cause.
Yes, that is one of the reasons we generally recommend using Chrome or Edge for Distill. The extension is more consistently compatible, officially supported, and regularly tested/updated for those browsers.
