I can choose 24 hours and 1 day as check interval. What’s the difference between those?
Hi @Milli
Firstly, welcome to our Distill community.
Internally, Distill stores the interval period in seconds & on the UI it will round it to the closest interval check.
Hence, at some threshold level it will show you in hours vs in days. Either of them should work well for your use-case.
Hope that helps answer your question.
Best Regards,
Surya
