I create the web monitor, selecto the part that i want to check for changes, selecto the sound notification buzzer, everything seems ok, in the log it detects the change but never give me the sound notification.
What can i do?
What can i do?
@zeraki Thanks for reaching out. Since the change is being detected but the sound notification is not triggered, let’s verify a few things:
Under Actions of the monitor, confirm that “Audio Notification” is added.
Which browser extension are you using?
Has the audio notification worked before and stopped recently, or has it never worked?
Open the Change History of the monitor and check if you see a bell icon next to each detected change and not a slashed bell icon.
On the extension Watchlist Dashboard:
Go to Settings → Device → Actions
Make sure Audio Notification is enabled there
Please check these and let me know your findings. This will help narrow down the issue quickly.
