I last used Distill in late September 2023. I want to start using it again to monitor the exact same page. However, it is not checking or updating it - I have the chime on so not getting that at all nor any of the recent changes. Not sure what I’m doing wrong? It’s quite urgent as I want to do the new work as soon as it appears. Thank you!
In general, following set of steps lead to an alert:
- A check happens. Confirm that they are happening correctly by checkout out the log of checks.
- If no error was detected, Distill should detect changes. Check the change history. To learn more about change history, please see Change history and highlighted changes – Distill.
- If Distill is able to detect changes, you should get alerts for actions configured in the monitor’s options. Arriving at this step is crucial to get alerts.
- If conditions have been added, alerts will trigger only if the conditions match.
Can you check the log out and see if the monitor is being checked for changes?
