I’m trying to monitor this website but it comes up blank in the Visual Selector. Any suggestions? Thanks.
thanks for reporting the issue @nhill87. i will check it out and get back to you.
in the meantime, can you try using the browser extension or the desktop app to select elements from this page? or, you can save without selection which will then monitor the full page.
