US visa tracking slots more than two months
I’m using Distill to track available US visa slots. I have set my macro and monitor to load and track for 6 months. However, I have noticed that only two months are visible for tracking. How can I track more than 2 months?
@conejo23
You will need to create three additional macros. Each macro will include steps to record clicks on the next button of the calendar. Below is the list of macros that you will need to save. The first macro is the one obtained by following the article.
  1. Calendar view shows May - June.
  2. After 2 clicks on the next button from the initial calendar view, it shows July - August.
  3. After 4 clicks on the next button from the initial calendar view, it shows September - October.
  4. One more Macro for November - December.
After creating the macros, you will need to assign them to four separate monitors. This ensures that each monitor checks availability for different calendar months.
Check out US-visa appointment slot dates - #2 by raksha for the details on editing the Macros.
from which country are you trying?
I trying from Dubai.
still no luck notification yet
