Unable to find “Concurrent Workers” option in Settings → Advanced
Hi everyone,
I’m trying to change the number of concurrent workers for local monitors as described in the documentation here:
https://distill.io/docs/web-monitor/cloud-local-monitors/
The docs mention that the setting should be available under:
Settings → Advanced → Concurrent Workers
However, I don’t see this option anywhere in my Distill settings.
I’m currently using:
  • Browser: Chrome
  • OS: macOS
I’m mainly using local monitors and wanted to reduce system load by lowering the concurrent workers count.
Has this setting been moved, removed, or restricted to certain plans/apps?
Would appreciate any clarification.
@legen_dary The setting is available only in the Extension Watchlist for Local Monitoring, not in the Cloud Monitoring watchlist at https://monitor.distill.io/.
Please try the following:
  1. Click the Distill extension icon in Chrome
  2. Click “Go to Watchlist”
  3. This will open the Extension Watchlist
From there:
  1. Click Settings (bottom-left corner)
  2. Go to Device → Advanced
  3. There you should find the option:
    “Maximum number of concurrent workers”
