Twitter monitor
Currently monitoring by selecting the number of posts under the name in the selector
[aria-level]~ .r-bcqeeo
However, there are times when the number is actually increasing but I do not receive any notifications.
This is a problem for both Cloud and DesktopApp.
I tried using this as a reference, but it doesn’t work, probably because I have fixed tweets on my account.
What if I only want to monitor post counts?
I am using a translator.
My best hope is to solve the problem of working in the cloud!
This could have been a simple problem.
It is probably a twitter spec.
You may not be able to read the latest unless you are logged into your account.
device:Desktop App
Log in on the screen that opens by clicking on the Desktop App monitor, that way you can monitor the numbers just fine.
I just want it to work in the cloud.
Is there a way to control the browser in the cloud?
Do I need to use a macro for this?
Translated with DeepL.com (free version)
using a dedicated device in cloud is a good option for monitoring sites that need you to be logged in. check out the following article:
see a related thread to help configure selections for twitter:
