Turkey consulate appointment tracking
I want to follow up on an appointment from the address below. I want it to notify me when an early appointment is available. I select the appointment template with “Parts of page”, but I think it sometimes creates a false alarm. Because when you go to the Distill address link, the page opens first, and the appointment window comes later. I think this situation creates a false-positive alarm.
My goal is to be notified when an early appointment is available from the link below. How can I do this in the easiest and simplest way?
https://www.konsolosluk.gov.tr/Appointment/Index/5018
Thank you very much for your support.
@arslanmuhammett7 when i open the link, it redirects to the home page https://www.konsolosluk.gov.tr/Home/Index and displays the following message:
Lütfen İşlem Yapmak İstediğiniz Temsilciliğimizi Seçiniz
you might see the same page if the link was opened in an incognito window. i initially thought that it needs a macro. but it may not be needed if you have already filled out the required details and the link displays the appointment’s details. is that correct?
can you try increasing the “wait for duration” for this monitor so that distill waits for a longer period of time before reading the page’s content? check out Config and Advanced Options – Distill.
feel free to reply if anything is not clear of if you need any help.
