Tricky iframe data
I’m trying to monitor an organization’s careers page (https://www.dscc.org/about-us/jobs/).
The content I’m trying to monitor is below the red bar in the screenshot. Nothing I do gets the monitor the track that data.
Looking at the source, that content is in an iframe, being pulled in from Newton. That redirects to a recruitingbypaycor script.
The page does have a lightbox popup, but that doesn’t seem to be the issue.
I’ve tried a few things to get Distill to see that content (including a macro, monitoring sections of the page, monitoring the entire page, loading remotely, loading locally, and monitoring both the Newton and RecruitingbyPaycor URLs). Nothing has done the trick.
Any suggestions?
using the browser extension (or the desktop app) makes it easier to select and monitor content in iframe. here are important things to note about monitoring content in an iframe:
  1. a monitor’s config selects an iframe using index property. the default value is 0 that corresponds to main frame (the top level frame rendering the webpage).
  2. the extension’s visual selector sets this index when selecting content within a frame. this is usually set as 1 if that iframe is the only iframe in the page. following screenshot shows what it looks like:
  3. some pages can have multiple iframes. the index may have to be adjusted if other iframes in the page can load before the monitored one. i had to change the index to 2 in this case.
here is the config that works for me using the extension:
  "ignoreEmptyText": true,
  "includeStyle": false,
  "dataAttr": "text",
  "selections": [
      "frames": [
          "index": 2,
          "uri": "https://recruitingbypaycor.com/career/CareerHome.action?clientId=8a7883c66859e564016861cef09767a1&parentUrl=https%3A%2F%2Fwww.dscc.org%2Fabout-us%2Fjobs%2F&gns=",
          "excludes": [],
          "includes": [
              "type": "css",
              "expr": "body",
              "fields": [
                  "name": "text",
                  "type": "builtin"
      "dynamic": true,
      "delay": 5
  "incognito": false,
  "regexp": {
    "expr": "",
    "flags": "gim"
  "blockAdsAndCookies": true
note that once the monitor has been configured using the extension, it can be configured to run in the cloud too. using a dedicated cloud device will be a good option to suppress the modal window from blocking the view.
