Subtract two rates being monitored on the same webpage
There are two rates being monitored lets say A and B. The difference between the two is C. Generally A and B changes but C remains same. I want to be notified everytime the C changes
@yashankdamani Just to confirm that I understood your requirement correctly.
Are you trying to monitor a section where A, B, and C are all shown on the page, and although A and B change frequently, you only want to receive an alert when the value of C changes, even if A or B change?
If that is the case, Distill currently does not support setting a condition on a specific element’s value while ignoring changes in other elements within the same monitored area. Since A, B, and C are all numeric values and change independently, the monitor would normally trigger whenever any of the monitored text changes.
One possible approach could be Monitor only the element that contains C, instead of the whole section with A and B.
To guide you properly, could you please share:
  • The URL of the page, or
  • A screenshot showing A, B, and C on the page
