Sticky window appearing in foreground
having issues for the last 2 months where the sticky window on chrome keeps jumping to the foreground, is this from a recent chrome change or can anyone assist? it used to always be silent in a sticky tab
@spoilern9 A couple of things to help narrow this down:
  • What version of the Distill Chrome extension are you currently using?
  • In the sticky window, is the focus rotating between tabs or switching unexpectedly?
If yes, could you try updating the Distill extension to the latest version and see if that improves the behavior?
Let me know what you observe after that.
latest chrome distil
the sticky window will just randomly come to the foreground, in the sticky window its opening up my monitors one by one and switching
@spoilern9 Thanks for confirming the details — that helps.
What you’re describing is a known issue, and the team is currently working on a fix for it.
I’ll keep you posted here as soon as we have an update and the fix is deployed.
@spoilern9 We’ve released an updated version of the Distill Chrome extension that includes a fix for the tab focus rotation issue.
Please update your Distill extension from the Chrome Web Store and check if the behavior is resolved.
Let me know if you’re still facing the issue after updating.
