Sticky option stopped working with error "No window with id:"
The sticky option stopped working with error “No window with id:”.
When I toggle the check system to Tab or Window it works without issue.
All Monitors stopped working.
Error Details
Code: NA
Msg:
No window with id: 1233748184.
Recommended Actions
There is no information about this error.
All Monitors report the following all the time, since about 2 weeks:
9:36 am EUNKNOWN
Is there a way to make it work? A recent update that broke it?
tested just not and worked fine for chrome and edge.
when using sticky window for checks, dwm opens a dedicated window (the sticky window) for opening tabs for checks. the error is logged if the sticky window is closed while the tab is being created for checks.
will you be able to check if there is an extension that can possibly close the sticky window automatically?
