Hi. I have a doubt regarding using macros for scheduling appointments. As you are aware after repetitive login attempts, the Visa appointment site blocks that user for a specific time period. Can you suggest any solution for this? Thank you.
Hello @nseit424 - you should work under the limits imposed by the appointment website. The primary way is by keeping check interval higher. There is no fixed guideline for this because it varies from one site to another. The general practice for Visa appointment sites is to use a 4-hour check interval.
Thank you for your reply.
