"Snip Unchanged" Option on iOS not saving context
Most of the time, I want all three options checked when viewing the latest compare: Show Deleted, Snip Unchanged, and Styled. After doing a little testing on my iPhone and iPad, it seems like Show Deleted and Styled will maintain their setting from one view to the next, but the Snip Unchanged always defaults back to disabled/unchecked.
On the Windows Desktop app, all three are persistent from view to view.
If this is a bug, would be great to add to the next iOS release. If it needs to be a feature request, let me know. :speech_balloon:
@rayharwood.goodclix a major revamp of the app was released recently which fixes this and other issues. can you check if you are using version 4.2.* and let me know?
Ah, thanks, Ajit… I just updated. The UI is a bit different – looks cleaner, but will take me a bit to find the view options!
OK… found my way around, and yes, the view settings are “sticky” now. Feel free to close this thread, and thanks for the quick response and excellent app!
great, thanks for the feedback and using distill. cheers!
