Selector isn't working on Edge (PC)
The selector won’t work on Edge on my PC. It does work with Firefox on the same PC, but Edge normally is more beneficial for my purposes. The selector is working on my Mac. I use browser extensions.
hello @rffl, thanks for reaching out and reporting the issue. edge extension version 3.10.20 regressed and introduced a bug where the visual selector may not load due to a race condition. this has been fixed in 3.10.22 which is currently under review. it should be publicly available in a couple of days. in the meantime you can install the updated version from the chrome webstore in edge: https://chromewebstore.google.com/detail/distill-web-monitor/inlikjemeeknofckkjolnjbpehgadgge?hl=en. thanks!
