We are not able to enable the MACRO view as indicated in the Tutorial description below.
“ç”
In the visual picker toolbar, select the newly added macro.
even after successfully creating the MACRO, it does not appear in the VISUAL selector.
The initial steps are easy, the big problem is to reconcile the programmed MACRO with the desired URL
