Does the Beta Live mode show as an active hit on a the website as such as a refresh does.
Also has anyone had issues with it lately? It seems like it worked better in the past.
@alertxxxxxx The Live (beta) schedule check doesn’t behave like a traditional page refresh. Instead, it keeps the page open and listens for changes (like a live session), so it may not register as repeated “hits” in the same way as interval checks. Performance can vary depending on how the website updates its content.
Could you share a bit more detail about the issue you’re seeing, or the URL of the website you’re monitoring? That will help us test on our side and guide you better.
Also, could you try using a Sticky window instead of a tab and see if you notice any difference?
