My monitor continues to send me push notifications to the app on my iPhone even though I have removed the push notification alert for the monitor. This uses up my quota quickly and I am trying to manage the 100 push notification per month but I am unable to turn them off. Any advice?
@kwatson2 If there are no Push Notification set under Actions, can you check if you have Push Notification set in “Global Actions”? This could be a possible reason why you are receiving the Push Notifications.
Steps are given below:
Click on the Monitor > Edit Options
Under Actions, click on Global Actions and check if you have any alert set.
Let me know if this helps.
I think that is it! Thank you! I will turn that off and see if it works.
