I wish to buy a product on amazon.in for a particular pincode. However, after login in amazon.in, wherein my particular pin code is put up as delivery pincode and putting selector for the product, i come back to watchlist, the pincode shows as Mumbai 400001.
How can i put selector for my address which is 382470 as i wish to check availability of product for my address 382470 not for 400001.
@rahul2110 If this is a local monitor set up through the browser extension, Distill should use the same browser/session when checking the page.
Please open the Amazon product page in the same browser and check which pincode is shown there. If the page shows 382470 in that browser/session, the monitor check should also use that pincode.
If Amazon still switches back to Mumbai 400001, you can create a macro for the monitor to set the delivery pincode before checking the product availability. The macro can replay the steps needed to enter/select the correct pincode.
