Best regards,
I am trying to set up the following website:
https://www.haciendabogota.gov.co/es/impuestos/impuesto-de-industria-y-comercio-ica
To configure this one like a monitor, I’m using a macro, because the section to track needs an additional step to be visible.
But, when I try to configure it, the macro detects a PDF file incrusted at the middle of the webpage:
What can I do to make Distill detect the whole webpage to select the specific section to track? Is the use of the #fanormas parameter possible, and how would it be used? This is to avoid using the macro.
I am attaching screenshots.
I am attentive. Thanks!
