Plugin only showing current device
Hi I use the Edge plugin. It used to show all my devices, including using the Distill servers. But now it only shows the current device plus the Application. I can see all the devices if I go to monitor.distill.io
Has there been a change in settings?
can you reinstall the extension and sign in to see if displays the watchlist and the list of devices correctly?
