Recently bought a new PC, and installed the Distill extension on Brave, but now I’m not receiving any notifications at all. Tried Syncing from the extension, and the list shows websites turned on, but nothing.
@discogsflipper - the most likely reason is the that monitors are still set to run on the old PC. Can you edit the monitors to run on the new device? Checkout Local Monitor vs. Cloud Monitor – Distill. You can use the current device using the devcie with name “… (this device)” or set it to use “Any Local Device”. Cheers!
