The PDF contains scanned images rather than selectable text, so Distill cannot currently capture and monitor its contents. We are working on OCR support for scanned PDFs and expect to support this type of document in a future update.
@srijith Thanks! Can we create distills for these committes? Only when we click we can see the pops information. can that be captured? Alabama Legislature
@srimathi.venkatachal Yes, the committee information shown in the pop-up can be monitored.
Create a Macro that clicks the required committee to open its pop-up. Then create a monitor, select the member information inside the pop-up, and attach the Macro to that monitor.
If you want to track multiple committees, create a separate Macro and monitor for each committee.
