I’m trying to record a macro on the following website
I appears that I’m not able to click in the search area (marked in yellow)
when recording a macro.
Hi @alextaxanalysts,
I tried clicking in the search area and I was able to record the macro.
Please find attached the macro steps json file which you can try to import & modify as appropriate.
Regards,
Surya
test1-ac90482d-e143-11ed-a44e-67735cc7c4e6.json (606 Bytes)
Surya, Thanks so much but I don’t get it imported. If I download the file to my computer and then try to import it, it doesn’t work. If I open it and copy the following data
{“macros”:[{“meta”:{“url”:“https://www.conseil-etat.fr/decisions-de-justice/jurisprudence/rechercher-une-decision-arianeweb"},“name”:“test1”,“spec”:{},“steps”:[[“wait_doc”,{“frame”:0}],[“scroll”,[“selector”,{“meta”:{},“type”:“css”,“value”:“html”}],0,1017,{“frame”:0}],[“click”,[“selector”,{“meta”:{},“type”:“css”,“value”:“.ng-isolate-scope”}],{“x”:731.5,“y”:212.453125},{“frame”:1}],[“type”,[“selector”,{“meta”:{},“type”:“css”,“value”:“.ng-isolate-scope”}],"sample input”,{“frame”:1}],[“click”,[“selector”,{“meta”:{},“type”:“css”,“value”:“.btn”}],{“x”:564.578125,“y”:199.03125},{“frame”:1}]],“version”:2}]}
it creates an error message (see attached).
I guess you are trying to import this as a monitor and hence its throwing the error.
You need to import the macro in your macros section via the following steps:
Please let us know, if you still face any challegnes.
Cheers,
Surya
If I click on import, it gives the following error message
“Failed to parse data invalid JSON” (see attached)
In other words, it doesn’t ask me for the file at all.
I believe you are trying to 'import a monitor’ and not ‘import a macro’.
Below are a few screenshots that can help:
Click on Macros as shown in the drop-down below.
Click on ‘Import Macro’, as shown in the screenshot below:
This should ask you to upload the file.
Hope that helps.
Cheers,
Surya
I have another website
https://eakta.birosag.hu/anonimizalt-hatarozatok
which does not let me fill in text while I want to record a macro. Do you have a solution for this one as well?
Thanks
Alex
I am able to record a macro (see screenshot below):
Once you import the macro & you can edit the text as shown in screenshot below:
Hope this helps!
Cheers,
Surya
eakta_briosag_hu-macro.json (588 Bytes)
