Monitoring while pc is off
Hello! Im wondering if theres any way to monitor a site, even when my pc is off. Im not on my computer alot, but I still want it to monitor. How do I do this?
@leoresell Yes — you can absolutely do that.
To monitor a site even when your PC is off, you’ll want to use Cloud Monitors in Distill.
How it works
  • Cloud monitors run on Distill’s servers, not your computer
  • They continue checking pages 24/7, even when your PC is turned off
  • You’ll receive alerts via email, Slack, webhooks, etc., whenever a change is detected
How to set it up
  1. Add a new monitor using the Distill web app
  2. When saving the monitor, choose Cloud as the device
  3. Set your preferred check frequency and notification method
For more information you can refer to the link below:
https://distill.io/docs/web-monitor/cloud-local-monitors/#cloud-monitor
For most public webpages, cloud monitoring is the best option if you’re not on your computer often.
