Hi, I’ve set up a monitor called TAS Forms > Estate Planning > General Enduring Power of Attorney. I have selected Form 4 as the monitored element but I would receive an alert every other day advising me that the monitored element is not the Enduring Powers of Attorney Fact Sheet. How can I ensure that the monitored element remains as Form 4 only?
the monitored elements depend on the selectors created to select them. if an item within a list is selected and the selection uses the item’s index as a criterion, a change in the item’s position will cause the selector to match a different element.
in this particular case, can you try to monitor the whole list and see what changed does distill capture? i can then suggest a solution based on your observations. thanks!
