Hello all, I want to monitor the SalesForce Lightning queue, so that every time the queue is populated by a new row, I get a notification … the queue itself is table html element, I tried selecting it using the selector but it notified me with every update. How can I do that ? Thanks
Hello @imamo, are you able to select a cell with td tag in that table?
Hi there, I have the exact same query. Can anyone help? I am not knowledgable on coding or anything else but would appreciate any help here! Thanks
Feel free to share details of your use case @trishmulvihill. We will be happy to help.
Hi @ajitk , @trishmulvihill and @imamo - where you able to solve this?
I am also looking to get a notification when a new row is added to a basic HTML table where the text contains a specific string. If you were ale to solve this could you please share your method?
Thank you!
@sbcgc here is a quick video that shows how to monitor any changes to a table.
Does this help in your use case? Feel free to share more details about what the problem is and I will be happy to help.
Cheers!
Thanks so much Ajit!
Part of my issue is that the table I am attempting to monitor updates regularly, can vary in the number of rows it has and pushes previous items lower down on the table. For my purposes I only want to receive notifications when the element contains “52 Div”
The website I’m monitoring is https://gtaupdate.com/ and I’d like to receive a notification when a new item is added for “52 Div” and see what that row is.
I’m new to coding but tried the below JSON:
"selections": [
"frames": [
"index": 0,
"excludes": [
"expr": "table tr",
"type": "css",
"fields": [
"name": "text",
"type": "builtin"
"filters": [
"name": "text",
"type": "not_contains",
"value": "52 Div"
"includes": [
"expr": "table tr",
"type": "css",
"fields": [
"name": "text",
"type": "builtin"
"filters": [
"name": "text",
"type": "contains",
"value": "52 Div"
"dynamic": true,
"delay": 2
"regexp": null,
"ignoreEmptyText": true,
"includeStyle": false,
"viewport": {},
"dataAttr": "text"
No luck so far.
Anything guidance you have is appreciated ![]()
I think I may have figured it out @ajitk using an XPath Selector?
//table/tbody/tr[td[contains(., '52 Div')]]
This is a good approach to filter rows in a table. Checkout following thread for a discussion on similar problem and solution:
Hey guys,
i want to monitor a table in a website to check for new rows/entries. I selected only the table instead of whole page. The problem is i get too many false positives. I get notification even if there arent any changes in the table. How can i narrow the selection so that i get a notification only if there is a new row?
I can select any cell with td if that helps
When i select first 2 rows, this shows on the configuration menu. Does it mean that it checks for first 2 rows or exactly the rows i marked for changes?
tr.hand:first-child
tr:nth-child(2)
Regards
A notification is triggered only on a change. What does the change history show? Maybe it is something minor that could be deselected.
When a new row is added to the table, is it added to the top of the list or at any position?
tr.hand:first-child selects the first tr element
tr:nth-child(2) selects the second tr element irrespective of their content
