Hello,
I tested the batch update to disable and enable all monitors and since then the status bar does not change and show the “Checking…” part anymore when a check is going on.
I tried a lot but I can’t seem to get it back.
How to enable it again?
Also, can I add a column showing the time of the last check?
Thank you!
