When i try to add any website for monitoring parts of their page, it says connected to remote browser, but web page doesn’t load, it gives error. Tried with different websites, same happenes. In case of selecting to monitor full page, it seems that works, so issue is with selecting to monitor part of page.
@zokibrt the err_tunnel_connection_failed is usually encountered when the remote browser is unable to connect to the website. some websites block connections from. as a test, can you check if you are able to load https://distill.io in the remote browser?
can you share the url too? you can dm it to me in case it can’t be shared publicly.
I just tested it, it works. I also tested 4 websites which didn’t work yesterday, but now they all work, which is suprising. I was on wifi yesterday (i can test again today once i be on it), but now tried on mobile data, it all worked. Yesterday i made sure that it wasn’t issue with wifi as i opened those websites in browser, while in Distill app didn’t want to open any of those, giving that previous error (in “monitor parts of page” mode, while for “monitor full page” mode worked anyway as mentioned yesterday)
thanks for the testing and sharing the update. feel free to reach out if you this problem happens again. cheers!
After some days of using the app, i noticed that i always get notification for one website even if there are no changes, and when i open preview of website, sometimes says some java error, sometimes not. I’ll share you link in dm.
what changes do you see in the history? diff in the text mode can be used to quickly find out what the change was the triggered the notification. see Change history and highlighted changes – Distill
I’ll read it, thanks! Now ironically there were no notifications for changes (but not actual real changes) of that site at all from the moment i mentioned that issue yesterday
(if it is/was even an issue)
