Memory leak in DDR5,7950X environment
Nice to meet you. I recently became a paying customer and started using it, but I had no problems with my Core i3 11gen ddr4 16GB environment, but with my Ryzen 9 7950X, X670E GENE, DDR5 32GB environment, a memory leak occurs and all 32GB of memory is used up.
The OS is Windows 10.
I reproduced it on all versions: Chrome, Edge, and Desktop APP.
Is there a solution? I’m Japanese and I’m using a translation, so there may be some parts that are difficult to understand, sorry.
this is similar to Some Problem with Desktop APP on WIN and LINUX - Help and Support - Community Forum - Distill. we are looking into it. it may take some time to identify the root cause and fix it.
the chrome extension should shouldn’t be consuming more than 4-5GB of RAM at peak usage. can you please share what you observed? thanks!
Thank you.
I gave up and decided to use it in an Intel environment! I look forward to future updates.
Thanks for the great application
