Login to monitor websites
Hello
Is it possible to monitor a site where you first have to log in?
If so, how do I set Distill to automatically log in to control the site.
Thank you very much
@viper the easiest way to monitor a site that require login is to use local monitors.
use the desktop app or the browser extension to log in to the site. you can then monitor the site as long as the session is active.
it you need to login automatically after being logged out, a macro (premium feature) can help do that this can work well. check out the following article and post for more information:
hope this helps. cheers!
