When I try to access the local monitor, by using the icon on the menu bar I get a small blank popup box appear. If I inspect that popup box I see the following error.
service.js:102 Uncaught TypeError: Cannot read properties of undefined (reading ‘SimpleStore’)
at new StoreProxy (service.js:102:38)
at new ServiceProxy (service.js:187:18)
at service.js:229:18
@al.davarzadeh
You can enable websql flags for Opera and it will start working. To enable flags in Opera:
- Type
opera://flagsin the URL bar. - Serach for
websqlin the search bar and enable it as shown below.
We will also make the necessary update and release the new version soon.
Thanks that has solved the issue
