I have been using distill.io for more than a year now. I use two different browsers, one where I run the checks locally, and another browser which I personally use and respond to notifications through. Since this morning, the live automatic syncing across the browsers has not been working, syncing the watchlist manually works fine. I tried to restart both browsers, uninstall and reinstall the extension on both browsers, I restarted my PC, and nothing is working.
Live syncing between browsers depends on a stable connection, so interruptions can sometimes be caused by factors like:
Temporary network issues
Browser state or extensions
Session or connectivity interruptions
Since it’s working again now, it was likely a temporary issue on the client side or network, and no action is needed at this point.
If you notice this happening again, it would really help if you could share the approximate timestamps when the issue occurred. That will allow us to investigate more precisely.
