Hello. I would like to report an issue I’m having:
I have a Monitor set to check frequently a page (since it updates very frequently) which has a Condition (regex) set.
If an update is detected by Distill and it satisfies the Condition, the status is properly set as “unread”. This works as intended.
But in case I don’t interact with Distill, leaving the Monitor in “unread” status, if another check runs and it detects a change but it does not satisfies the Condition, Distill sets the Monitor to “read”.
If I check Distill at this time, I am made to believe that no changes ever happened to the page.
What should happen is that if the Conditions on a Monitor are not satisfied, but the Monitor status was previously “unread”, than the Monitor should keep the “unread” status still.
I don’t know if this is bug or a feature, but in my case it severely hinder my ability to use Distill. If there is a workaround I’m more than happy to hear it.
Thanks for the attention.
