Hey @littlepupil, thanks for reporting the problem. The blank popup looks odd. It is an indicator that some unexpected error was encountered. Can you try to inspect the popup as shown below:
A dev tools window should open up. Do you see any errors in the console there?
The extension failed to initialize correctly. This error is related to data storage. Can you try and reinstall the extension to see if that helps load the extension correctly?
I removed it and added it again to the chrome but still can not work.
Did the popup not show up even once after clicking the Distill icon in browser toolabr after the reinstall?
