Hi to all, I’m a new user and I have to monitor a webpage and I would like to get a warning when the phrase (OUT OF STOCK) disappears. I selected the part of page with text and in the conditions I entered Continue only if text contains OUT OF STOCK. Is everything right?
Thank you
If you want to receive an alert when the text out of stock disappears, you don’t need to use conditions. Simply select the text and proceed with monitoring. Whenever the text changes, you’ll receive an alert (in this case, when out of stock changes to something else).
Conditions allow you to receive alerts only when a change occurs and matches the specific criteria you’ve set.
Ok, thank you. I asked because one monitored page changes and I don’t receive any alerts…
is there a condition set? if yes, check out https://distill.io/docs/web-monitor/using-conditions-to-get-alert-on-important-changes/#how-to-find-out-which-condition-triggered-the-alert to see how it was evalutated.
No there isn’t any condition. I find out the problem, I’m on Mac and the app is missing on notifications center… I’ve just download chrome extension and now I hope is all ok!
Thank you
