i am not able to get notifications for product added as to notify when add to cart is shown on a particular website. Tried in stock product still no notification, any fix for this?
Hi @vinayaksoni007,
Alerts are only received when:
- there is a text change when Distill checks the monitor, and
- conditions (if any) is true.
So, for in-stock product as there is no text change, no alerts can be received.
Can you see if the monitor is running successfully with no error showing in the check-log and the above is true? See How to check logs in Distill web monitor? | Distill.io to know how to view check log.
