"I am not a robot" error
I am using the software on hasznaltauto.hu, and sometimes it works, sometimes it doesn’t. The problem is that there is an “I am not a robot” check, when a page is opened. Is there a good solution for this?
@jasiauto Thanks for reaching out.
What you’re running into is a CAPTCHA / “I am not a robot” check, which is the website’s way of blocking automated or cloud-based access. Unfortunately, there isn’t a reliable way to bypass or automate CAPTCHA challenges at the moment — this is a limitation across most monitoring and automation tools.
That said, I did notice that hasznaltauto.hu loads normally when accessed locally in a regular browser, without consistently triggering the robot check. Because of this, the best workaround right now is to use Local Monitoring.
Recommended workaround
You can monitor this site using:
  • The Distill Chrome extension, or
  • The Distill Desktop app
Local monitors run directly from your own browser or machine, using your IP and session, which makes them much less likely to trigger CAPTCHA checks compared to cloud-based monitors.
