Hello! Is it possible to detect changes behind the loaded content when you select the Platform in this example website? Add dummy text in Todoist If yes, can you please share the steps to set up the monitor? Thanks!
@sergiow a macro can be used to select the option and then monitor content rendered for the chosen option. Please see the introductory article about macros in Distill:
The steps are:
- Create a macro to select a specific option in the page.
- Create a monitor using the macro and execute it.
- Monitor content.
Distill will then run the macro every time before monitoring its content.
Feel free to reach out if you have any questions or need any help. Cheers!
Thank you, Ajit!
Unfortunately, it looks like I need to upgrade my account to access this feature.
Would it be possible to have access to a trial period?
Sure, do have an iOS device? You can then opt for a 7-day free trial using the App Store to subscribe. You can cancel immediately in case you don’t want it to auto renew.
