How to get Distill to "click" on a "I'm over 18" popup?
Hi all, I have a Distill monitor for a firearm product that is currently out of stock. When Distill opens the tab to check the page, there is always a “I’m above the age of 18, Enter” popup that I have to manually click on.
Is Distill somehow still able to check the page contents even when this popup is visible? If not, how can I program Distill to click past it?
Thanks.
if the content is rendered behind the popup, distill can monitor the selected data. when selecting content to be monitored, make sure to close the popup manually.
a macro can be used to click the popup’s button when it shows up. check out [Feature] Conditions in Macros - Announcements - Community Forum - Distill.
