How to customize the Discord notification (using the actions "Discord Notification" or "Webhook Call")?
Hello!
I would like to customize the Discord notification that is sent to the Discord channel when there is a change on the page.
I’ve tried both actions “Discord Notification” and “Webhook Call” when I set the monitor, but I don’t manage to change the text that is sent out to Discord.
Does anyone have a solution please?
Thanks!
A raw webhook can send any text you need to send. Using content field can help. Following screenshot contains an example:
Thank you @ajitk ! I managed to customize the text sent to Discord, but do you know how to delete the “Powered by Distill.io” thing ?
I tried to add a “footer” but it doesn’t work.
Thanks !
