I need to understand how deselect works exactly and want to know if what I want to do is possible.
I know that I can select a parent element and then deselect some children inside it.
But is it possible to select X elements and filter those elements by deselecting some of them?
Hello @detectthis, thanks for sharing your use case. A deselection is used to exclude elements within an existing selection.
I could not access the example page on jsbin. Based on the screenshot, you can use following CSS selector to filter out the elements that you don’t need:
