I’m following my competitor’s prices. They have a price and a discounted price. I select both, but when I export, I see both values in the “text” column. Is there a way to export them separately?
does the monitored text include the currency symbol? if yes, the symbol can be used to split the text into two parts.
OK, thanks, How can i do this?
SPLIT
is a standard function in spreadsheets .check out SPLIT function - Google Docs Editors Help as a reference.
Okay, I’m clear about Sheets or Excel. My question is whether it can be done directly from Distill. It’s quite inconvenient to have to use an external application after exporting the results.
Thank you!
