HELP: Facebook Marketplace ever-changing CSS class names
I am curious if you know of a way to monitor Facebook Marketplace? Right now, they have garbage names in their CSS classes like ‘xzvvcxz’ that change out every hour, so the Distill monitor fails since the CSS value changed. But, they do have a fixed aria-label=“Collection of Marketplace items” that perhaps I could latch onto for checking?
So the question is - is there any way to check this unique aria-label tag in a distill query?
Here it is in the code:
Hi @612mc, welcome to the community forum. Selecting the elements that have the aria-label="Collection of Marketplace items" attribute should be possible using the following CSS selector:
[aria-label="Collection of Marketplace items"]
Notice that I have changed the double quotes character. Can you try it out and see if it works? Make sure to use the CSS selector type when using this selector.
Cheers!
I think it might have worked! No errors yet. Here is my config, looking good?
  "selections": [
      "frames": [
          "index": 0,
          "excludes": [],
          "includes": [
              "type": "css",
              "expr": "[aria-label=\"Collection of Marketplace items\"]",
              "fields": [
                  "name": "text",
                  "type": "builtin"
                  "type": "attribute",
                  "name": "aria-label"
      "dynamic": true,
      "delay": 2
  "ignoreEmptyText": true,
  "includeStyle": false,
  "dataAttr": "text"
Yes, looks good! I edited the post to make it appear as code as shown below:
{code}
could I make this work to just monitor vehicles for sale? curious if it is still working for you?
I think I found a better way, building on your idea. What I use is the following xpath:
(//div[@aria-label="Collection of Marketplace items"]//span[@aria-hidden="true"])[position()<=8]
This checks the title and location of the first 4 results on the Marketplace search page. Remove [position()<=8] for checking every result loaded without scrolling. Change 8 to 2 to only check the first result.
Be aware that the URL doesn’t contain the search location and radius info, so if you change those when you manually search, your Distill monitors might trigger, since they’ll also use the modified location. If the location and radius is stored client-side, than a separate container in Firefox or using the desktop app might solve this issue, but I’m not sure, since manually resetting them to a single value for all my searches is sufficient for me.
Is there a way to modify the xpath to include the images of the marketplace listings that are detected? Thank you :slight_smile:
@amery15 To include images and show in the change history, you can add one more Xpath expression
(//div[@aria-label=\"Collection of Marketplace items\"]//img)
To monitor the title and location of the listed items for top 4 results, you can update your expression as suggested in HELP: Facebook Marketplace ever-changing CSS class names - #8 by koltrast
Here is the final config if you would like to monitor the title and location of the top four items. The config also includes the expression to show images in change history.
  "selections": [
      "frames": [
          "index": 0,
          "excludes": [],
          "includes": [
              "type": "xpath",
              "expr": "(//div[@aria-label=\"Collection of Marketplace items\"]//img)[position()<=4]",
              "fields": [
                  "name": "text",
                  "type": "builtin"
              "type": "xpath",
              "expr": "(//div[@aria-label=\"Collection of Marketplace items\"]//span[@aria-hidden=\"true\"])[position()<=10]",
              "fields": [
                  "name": "text",
                  "type": "builtin"
      "dynamic": true,
      "delay": 2
  "dataAttr": "text",
  "regexp": {
    "expr": "",
    "flags": "gim"
