Full Screen Monitor gone Once in a while
Good Evening , I been try to make a monitor automation for my friend and i stuck with some weird situation.
The program did full screen monitor and it gone for the next time. like picture showing here
I been setting delay times to 8scd. I adjust according to my regular browser speed to get inside the web. Does it a bug or i miss some documentation?
I set the condition once Out of Stock and Sold Out text is gone it will ring me at discord .
But when it failed , it trigger the condition i set there..
when monitoring full pages, giving it more time to load is a good idea. it can be done by increasing “wait for duration”. it can be configured in the monitor’s source configuration. please see Config and Advanced Options – Distill.
if monitoring the full page is not a necessity, monitoring a more specific part of the page is a better idea. check out: How to monitor parts of a web page using Visual Selector?. monitoring the product’s title, price and out of stock status should work much better.
lmk if you need any help. cheers!
Good Evening. Thank for reply.
Yes i adjust the monitor time to 15-18scd cause i check network tab when reload site take around 12000ms to finish.
but it still happen to be same problem.
It solved using condition to filter false ping so far still working.
Btw do we have the option to download acticity log into txt or csv file. I want check explore diff catching any weird thing.
Oh for the specific part of the page , it always return SELECTION_EMPTY unless i manually click into the page. still trying and try to giving feedback for this
this implies that the page is not rendering completely when opened in a background tab. it needs the tab to be active. the desktop app or cloud should work well in these cases.
Understand. Thanks a lot. It seem whole page monitor also did EXECEPTION for long time run. I switch to the app everything seem fine now. Thanks again :folded_hands:
