Hi all,
Has anyone tried using Distill for monitoring visa slots on https://visa-fr.tlscontact.com/visa/gb/gbLON2fr/home ?
Any advice would be greatly appreciated, thank you!
Hi all,
Hi @mgzl1166
Firstly, welcome to Distill’s forums.
I’ll recommend you to take a look at the forum thread: Checking availability for the US visa appointment - selection empty error
In most scenarios (associated with Visa appointments monitoring), you will have to login to the portal and perform a set of steps to reach the calendar which can be monitored. To address this challenge, you will need to use macros in Distill.
A typical process to setup a montior will look like the following:
Furthermore, I’ll also recommend that you keep the frequency of checks to about once every 3hrs. This will ensure that the monitor will not run at a reasonable frequency.
I’ll be happy to connect with you over a zoom call, if you still face any challenges and need help.
Best Regards,
Surya
