I’m trying to set up a monitor on a page that republishes each day creating false positive alerts.
Main issue is each page creates a ‘Printed on 15 Jun 2024’ text field change.
Does anybody have advice on what html selector or way to deselect this text, in the form of “Printer on x x 20xx”?
It doesn’t appear to be a timestamp.
<span class="text-marine-blue mr-2" >Published: December 2023.< /span > < span class ="text-marine-blue d-none d-print-inline" >Printed on < ins> 15< /ins > Jun 2024.< /span > < /p >
@blackemissions you should be able to deselect the element with the timestamp using the visual selector.
check out the following article that shows how https://distill.io/docs/web-monitor/what-is-visual-selector/#how-to-exclude-elements-from-the-selection-that-you-do-not-want-to-monitor. try the method using the visual selector. if the date is contained within its own element, this method should work.
